60k Maintenance
david, what is homelink?
stearns, i don't know if youre under the impression that the bose system doesn't have the cd changer, but that's incorrect. my bose system has the changer, and i believe all bose systems included the cd changer.
Premium sound = Bose. If you have Bose there will be a Bose badge on the door speaker grills. If you have Bose and no cd changer, then the changer has been removed.
A chipped 1.8t is much more fun to drive than a stock 2.8. You CAN get a chip for the 2,8, but it is fairly worthless and not worth the money.
Timing belt is not a hard job to do by yourself. Time consuming, but not hard, especially with all the good tutorials out there (like on AW). I did the change on my 1st audi without any prior knowledge. Only had to buy a couple basic tools.
Full 60k service includes:
Usual checks on brakes, fluids...
Oil/filter
Air filter
Spark plugs
Timing belt
T-belt tensioner roller*
Serpentine belt
Water pump*
Thermostat*
Coolant flush*
* Optional - and assuming you do the timing belt job
Oil/filter
Air filter
Spark plugs
Timing belt
Serpentine belt
Water pump*
Thermostat*
Coolant flush*
