90k tune up
Old Jan 4, 2006 | 04:54 PM
klum00's Avatar
Default 90k tune up
so its time for my 90k tune up, and i am trying to figure out if i should do it myself or take it to the dealer and blow the $2000 or whatever they would charge me. how easy would you say everything is to do. also are is there any thing that isnt really necessary? im definately not an auto technician, but i know what im doing when i work on my car. any help would be appreciated. oh yeah, its a 96 2.8 quattro, thanks guys.
Old Jan 4, 2006 | 05:27 PM
Kellya4's Avatar
Default RE: 90k tune up
That's actually not hard, they change the oil and filter, pollen filter, spark plugs, air filter, check all fluids, etc.. I don't know if they change brake fluid as part of that as well or not, but it's easy stuff, as long as the timing belt has been changed already. If not, bring the vaseline and bend over.
Old Jan 4, 2006 | 06:10 PM
clconversion's Avatar
brake fluid changes are done every 2 years the older A6's do not have pollen filters so don't worry about that
Old Jan 4, 2006 | 08:49 PM
klum00's Avatar
the belt hasnt been changed in a long while, so im guessing thats gonna have to get done. i assume i should avoid the *** raping and take it in?
Old Jan 4, 2006 | 09:28 PM
CRAZYHAWK's Avatar
Spark plugs and air filter should have been done at 80K mi. Change oil with synthetic that meets ACEA A3.
Find an independent mechanic that works on German cars to do the timing belt.
www.audifans.com
http://1.8t.org
Good luck.
Old Jan 5, 2006 | 01:56 PM
onepoint8tee's Avatar
ORIGINAL: klum00
The *** raping would occur if you were to take it in.
Old Jan 5, 2006 | 02:14 PM
Kellya4's Avatar
If the timing belt needs to be changed, find an independant mechanic that works on audis to do that instead of the dealer, it will save you a lot of money. Have the water pump changed while you are at it as well. Where are you located? Someone here should be able to direct you where you should go.
Old Jan 5, 2006 | 02:17 PM
Kellya4's Avatar
Nevermind, i see that you are in Silver Springs, Maryland.
Old Jan 5, 2006 | 09:36 PM
John_E's Avatar
I have a 1996 2.8Q, as well. You do NOT need to use synthetic oil on this particular engine (unlike the hot-running 1.8T), but you will get longer OCIs if you do. You definitely need to do timing belt, thermostat, water pump, radiator hoses, accessory belts, and cooling system flush.
If you have an automatic, I strongly recommend a full pan drop ATF and filter change ($300, but cheap insurance).
Old Jan 6, 2006 | 11:53 AM
klum00's Avatar
im actually living in baltimore now, if anyone knows someone good around here...
judeisnotobscure
Sep 14, 2015 12:28 AM
rsonistxl
Oct 19, 2009 07:05 PM
01TT225Q
Aug 15, 2008 08:43 PM
phlash
Jul 26, 2007 04:26 PM
225tt
Nov 3, 2006 12:51 PM
