96 A4 Air Conditioning
Old May 30, 2005 | 10:45 PM
Docxy's Avatar
Default 96 A4 Air Conditioning
How do I check the freon level in a 1996 A4 Quattro?? My compressor comes on but the air that blows out is never cold? What else could be causing this?
Old May 30, 2005 | 11:18 PM
david9999's Avatar
Default RE: 96 A4 Air Conditioning
Most likely it is low freon. could be bad compressor.
On the 1.8 there is a secondary electric fan that runs when the A?C is on. If this isn't working, your A/C will cut out.
Old May 31, 2005 | 12:05 AM
BFlan2001's Avatar
most a/c refill stations will check your freon level for free. it's not something you can do yourself though, it has to be done by a professional
Old May 31, 2005 | 11:20 AM
CRAZYHAWK's Avatar
Make sure your car uses R134A. You can buy a 19 oz can of R134A with lubricant and stop leak that has a gauge built in. This sells for $25. You insert it in the low pressure side with the compressor running.
lumpyd
Jun 18, 2013 09:36 AM
1.84life
Jun 20, 2008 01:21 AM
godowninflames
Apr 21, 2008 09:26 PM
Robsa4
Oct 7, 2007 01:44 AM
S4Goose
Jul 2, 2007 06:33 PM
