96 A4 HVAC light
Old May 30, 2007 | 10:50 AM
jonellebel's Avatar
Default 96 A4 HVAC light
My HVAC lights on my 96 A4 started flashing on and off, but now doesn't work at all. Is there a bulb behind the unit that can be replaced? Any help on getting to it would be appreciated.
Old May 30, 2007 | 10:52 AM
jonellebel's Avatar
Default Exhaust flex pipe hole
My exhaust on my 96 A4 is solid, with the exception of a hole in the driver's side flex pipe. Can the flex pipe be cut out and replaced with a solid piece, or is the flex a must? What about replacing just the flex pipe? I hate to replace the entire system since it's just that one spot.
Old May 30, 2007 | 10:56 AM
techbod's Avatar
Default RE: Exhaust flex pipe hole
you can have the flex pipe replaced without changing everything but you cant fit a solid pipe in its place due to movement of the engine which is why its there
vtraudt
Feb 9, 2022 08:31 AM
2008/A6
May 23, 2015 10:48 PM
rmr1499
May 14, 2014 03:48 PM
neomaxddr
Apr 1, 2009 03:20 AM
sonneboz
Sep 19, 2007 05:33 AM
