96 A4 Question
Old Oct 23, 2007 | 09:12 PM
RYANHASADD's Avatar
Default 96 A4 Question
I have just purchased a 96 sudi A4 quattro. I noticed that when I first start the car there is what looks to be the " 1n2 " flashing where the trip odometer is. Anybody know what this is? I am new to audis and no nothing about them. The car also has a check engine light on. The guy I purchased the car from said it was from a bad EGR valve. He was told this by his mechanic. He never had it replaced as it is 408 dollars for one from Autozone and they are not really restrictive on emissions here in south carolina. Can I take the EGR valve out and clean it in gasoline or solvent? Where is the EGR valve located and how hard is it to get out?
Old Oct 23, 2007 | 10:24 PM
CAB509's Avatar
6th Gear
Default RE: 96 A4 Question
Hello and welcome to Audi.
First of all the ln2 is an indication that your car is under teh millage that suggests extra maintenance, it is a factory set interval that repeats so they fact it is on is not a bed thing.
If your car is throwing a CEL then your EGR valve might be the problem.
the EGR valve looks like this , I believe that if you take off the ingnition coils on the passanger side of the engine right up next to the manifold is where you will find this part (or something that looks a lot like it)
Old Oct 23, 2007 | 10:28 PM
wood_e's Avatar
Coils? Nope the EGR valve is right next to the throttle body. Check audiworld for a write up on how ot bypass it. The 1n2 thing is a factory maintenance schedule which can only be changed with a VAG-COM. I changed mine to 99,000km, since I know when to maintain it, but that doesn't matter anymore.
Old Oct 23, 2007 | 10:34 PM
CAB509's Avatar
6th Gear
ORIGINAL: wood_e
thank yo for correcting me. I need to replace mine possible but wasn't sure exactly where it was.
Old Oct 23, 2007 | 10:38 PM
wood_e's Avatar
No prob! It's a silver disc type thing - You'll see it... you might want to check the vacuum lie to it too.
Old Oct 24, 2007 | 05:05 AM
andysuth's Avatar
ORIGINAL: wood_e
I can't remember if it was LN2 or LN1 that was flashing on mine when I bought it. I did an oil change myself and you can cancel the one I had with a simple series of ignition key, clock button and trip counter button presses.
I'll look it up tonight. LN1 is a 10,000 mile service (Oil Change). LN2 is a 20,000 service (Fuel Filter andevery other one a particulate filter). On Pre-1997 A4's youmight need a cable for both to be reset but on my (1998) A4 I reset it from instructions in the drivers manual.
I don't think you need a cable for it anyway on post 97 A4s. Not much help since yours is a 96! but if anyone googles this, might clarify matters.
EGV is just in front of the driver at the top of the engine (looking from the open bonnet it's on the left) It's bolted on to the engine by four bolts on a flange, and has a vacuum tube running (cabin side). Replacing the vacuum tube is supposed to be a quick (& cheap) fix if you try it first. If the valve is silted up, you'd probably waqnt to change the vacuum tube anyway. Cost less than a fiver.
-AS
Old Oct 24, 2007 | 05:11 AM
Limbs's Avatar
oh so thats what it is.
EvoTillIDie1
Mar 5, 2014 10:42 PM
manindra
Feb 10, 2009 05:59 PM
SouthernAudi
Oct 14, 2007 06:47 PM
viper771
Mar 7, 2006 05:52 AM
