97 1.8T Mechanical Fan Removal - HELP!
Old Jan 15, 2006 | 07:47 PM
T_REV_17's Avatar
Default 97 1.8T Mechanical Fan Removal - HELP!
I am having problems removing the mechanical fan from the engine (to get at the water pump). My manual (Haynes) says to use a spanner wrench to hold the idler pulley and loosen the central nut between the fan clutch and the pulley. My Audi does not have this nut. It is a smooth shaft. I have noticed a bolt of somekind on the backside of the idler pulley shaft shroud but I am not sure it was designed to be loosened and I don't want to screw something up.
Any advise would be appreciated.
Old Jan 16, 2006 | 03:42 AM
ecartoys's Avatar
Default RE: 97 1.8T Mechanical Fan Removal - HELP!
Hee Hee. Haynes did not tell you the fan clutch is a left hand threaded nut. To do the job without confusion you need Bentley.
You need a very slim but long wrench to lock into the nut and use a hammer to knock it loose. If the fan clutch has never been replaced now is a good time. To check you can try hand turning the fan when the car is cold. If you can feel resistance you are OK. If it free spins you need new one. It is not cheap - $92.78 at my store.
PS. You will need to make sure the belt and pulley stays put when you hit the wrench.
[IMG]local://upfiles/13162/C010EE9A1DF74C3989DAEE818C805441.jpg[/IMG]
Old Jan 16, 2006 | 03:47 AM
trailboss's Avatar
I believe its a 32mm spnner wrench.
Old Jan 16, 2006 | 03:54 AM
ecartoys's Avatar
Yep. I use bicycle shop wrench because they are very slim yet strong.
Old Jan 16, 2006 | 04:13 AM
trailboss's Avatar
^^ yep work force or park tools carries them at most bike stores, use to build and tune bikes up for 4 years.
Old Jan 16, 2006 | 05:33 PM
T_REV_17's Avatar
Thanks for the advice, however the nut you speak of DOES NOT EXIST ON MY AUDI. There is NO nut between the fan clutch and the pulley.
That is my problem. I have no place to put the wrench onto.
Old Jan 16, 2006 | 06:22 PM
Kellya4's Avatar
ORIGINAL: trailboss
That would be Wrench Force, it's the tool side of Trek.
Tool runs $20 retail.
Old Jan 16, 2006 | 06:33 PM
techbod's Avatar
gentlemen the water pump is driven by the serpentine belt/aux belt the big spanner job is for the older cars
Old Apr 14, 2011 | 04:07 PM
swimbigd12's Avatar
I have the same problem on my 1999 a4 1.8t!!!!
I dont know what to do either....
96whitea4
Jun 3, 2012 07:37 PM
CitizenKane
Oct 8, 2010 10:28 PM
SVT_BRYAN
Nov 24, 2009 09:45 AM
autohaus_meredith
Dec 5, 2007 08:21 PM
True_Pinoy
May 23, 2006 04:47 PM
