97 A4 2.8 fwd. NEED HELP ASAP!!!! Idk what i did to it but its bad.
Old Dec 19, 2015 | 11:53 PM
amilanko's Avatar
Default 97 A4 2.8 fwd. NEED HELP ASAP!!!! Idk what i did to it but its bad.
i have a 1997 audi a4 2.8L fwd automatic. it was running perfectly fine. but then i had removed spark plug wires 1 and 2 overnight so my dad wouldnt drive it. i went to started it in the morning without remembering to reconnect them, it wasnt running right, and by that i mean it took a sec to start and ran shakey and was idleing really low. i drove it about 2-3 blocks before it started running worse and worse till i remembered i forgot to reconnect the wires. i parked and let it sit for a few minutes just cause. when i got back in, to go home and grab the wires, and tried starting it, it barely started only after i gave it a lil gas and when i put it into drive and pressed the gas it bogged out and died. i immediatly tried starting it again, and quickly threw it in drive and i got until the next stop light when i had to stop reving it,and it died and wouldnt restart. i had to push it to the side and i quickly ran home to grab the wires. when i reattached the wires it started but ran really bad. it smelled bad, sounded bad, ran shakey, shifted at a higher rpm(3,000 instead of its usual 2,500), when accelerating theres a lag, and still idled so low it was threatning to shut off. when i got home i decided not to drive it until i found out what i did. like i said earlier, before i drove it with out those spark plug wires unattached it ran perfect so im pretty postive i messed it up then. can anyone plz tell me what i did to it and if i can fix it, or am im screwed/take it in to the machanic. either way if someone can just give me an idea at what happened that would be awesome!!!!!!
Old Dec 22, 2015 | 10:15 AM
markymarc's Avatar
Well, if you put the spark plug wires back on on the wrong cylinders, wrong order it would cause that.
Old Dec 24, 2015 | 02:31 AM
amilanko's Avatar
thats what i was thinking. do u know the right order?
Old Dec 24, 2015 | 09:52 AM
markymarc's Avatar
Here you go. Front of car is where the distributor drawing is.
Firing order is: 1-4-3-6-2-5
Attached Thumbnails 97 A4 2.8 fwd. NEED HELP ASAP!!!! Idk what i did to it but its bad.-image.jpeg
Mr. Phil
Feb 26, 2011 09:28 PM
Bugs
Nov 2, 2010 07:00 PM
cmk87
Nov 8, 2007 11:26 AM
cmk87
Nov 6, 2007 07:18 PM
PandaXpress
Feb 28, 2005 04:11 AM
