99 1.8t help
Old Feb 3, 2006 | 07:32 PM
99_A4's Avatar
Default 99 1.8t help
ive been having some problems with my a4, when i got it pluged into the computer it said the #1 piston is misfireing. so they guy at audi told us to order another coil and that didnt work then i just got the part that gose between the spark plug and the coil( i dont know the exact name). And still its has a rough idle and vibrates alot. I changed the plugs too. Im not sure whats wrong. From what i found online the #1 piston is the 1st from the front of the engine unless that was wrong, im not sure what else to do.
thanks
Old Feb 3, 2006 | 07:40 PM
techbod's Avatar
Default RE: 99 1.8t help
is it a misfire problem or is it running on 3 cylinders??
Old Feb 3, 2006 | 07:41 PM
techbod's Avatar
misfire is like a back fire
Old Feb 3, 2006 | 07:49 PM
99_A4's Avatar
its running on 3, sorry for the confussion, im going by what i was told.
Old Feb 3, 2006 | 07:56 PM
techbod's Avatar
failed coil pack
Old Feb 3, 2006 | 08:02 PM
99_A4's Avatar
i guess ill have to check the 2 more pistons then, i got a new coil pack, i was told it was the #1 piston so ill check the rest and see if it works.
Old Feb 3, 2006 | 08:07 PM
techbod's Avatar
compression check required on all cylinder would be a good thing then post your results
Old Feb 3, 2006 | 08:58 PM
99_A4's Avatar
Ok, I moved the coils around to see if I could weed out the bad coil pack, no luck. Im not sure how to check for compression, if I need to use a vag, im gonna have to wait till monday to use the one my school has. or I might have to go get it checked out.
Old Feb 3, 2006 | 09:01 PM
techbod's Avatar
Old Feb 3, 2006 | 10:02 PM
99_A4's Avatar
ok thanks, im sure i can get one of those this weekend. if not im sure monday ill be ableto do it.
