99.5 A4 1.8TQ + Borla Cat back..........
Old May 26, 2006 | 07:56 PM
K1196A's Avatar
Default RE: 99.5 A4 1.8TQ + Borla Cat back..........
i doubt it, but we can work on that assumption if you like!
Old May 26, 2006 | 07:59 PM
BaconBait's Avatar
I highly recommend getting a test pipe or high flow cat at the same time. The bolts connecting the downpipe to the cat are extremetly difficult to get off. Mainly because of where they're located, but also because they will be rusted to hell.
Old May 26, 2006 | 08:01 PM
onepoint8tee's Avatar
ORIGINAL: K1196A
Never doubt yourself... Its a pretty simple concept, you'll catch on.
Old May 26, 2006 | 08:14 PM
K1196A's Avatar
I'm sure with your Jedi like teaching that anything is possible! Ewwww, I wish you could see it -- I just levitated my A4 with my mind......... Thanks Jedi Master Onepoint8tee
I see the testpipe eliminates the the cat behind the turbo (the search function does work), how does that effect emmissions testing? seems like that would be an issue,
Old May 26, 2006 | 08:24 PM
forcefedaudi's Avatar
OBDll cars get tested through the computer for codes to pass emissions at least in ny, look in the diy for the no cel test pipe and your emiisions problem is solved
Old May 26, 2006 | 08:33 PM
ORIGINAL: K1196A
I am happy to hear of your optimism my young apprentice. Through my teachings, you will learn to control the force at levels which you cannot forsee at this time. So long as you mind my teachings, you will advance from being able to levitate an A4 to being able to levitate an A8 in short time.
Good to know the search still works!
There is a "No CEL with test pipe" mod on Audiworld.com i think. Depends on how the emissions test is performed though But these days they go through the OBD port which makes passing emissions easier than the "hook up a hose to the tail pipe" way.. There are other ways which can be found in the........ you know...
K1196A's Avatar
that looks like a little more then i need/want to get involved in to beat the test. not sure how they run the test here in PA. the 15 or so HP would be nice, but looks like a pain and like something to have to fuddle too much with.
Old May 26, 2006 | 08:36 PM
  #18
ORIGINAL: K1196A
Its easy... Just look up the DIY.. Many people do it.. You could always gut your cat-but thats more work than the DIY for the test pipe and im sure you dont wont to fuddle with that either.
Old May 26, 2006 | 08:37 PM
  #19
i just installed my test pipe, yes it sucked but if your putting a new exhaust in its much easier. the hardest part was getting the cat out, once that was done it take maybe an 1.5hrs to make sure everything was siting right but i attached it to the factory exhaust wich had rusted bolts.
Old May 27, 2006 | 03:31 PM
  #20
K1196A's Avatar
OK -- thanks to all of your bad influences, I just ordered one -- hopefully by next weekend the setup will be on!
