99 a4 1.8t - cylinder not firing
Old Aug 28, 2005 | 04:16 AM
badfeet's Avatar
Default RE: 99 a4 1.8t - cylinder not firing
^^ i second
Old Aug 17, 2010 | 08:39 PM
emily0918's Avatar
I am having the same problem with my 99 1.8t. mine has 123k miles on it. Brought it in; changed MAF, Ingintion control module, coil packs spark plugs, air filter fuel filter, and its still getting a check engine with cylinder 3 misfire- and stuttering so bad i can barley drive it. no idea what it could be. also the compression tests came back fine.
Old Dec 17, 2010 | 09:59 PM
djcctek's Avatar
Default Same luck here...
Cylinder 2 misfire. Changed all 4 plugs swapped coil 2 with 3 and still misfire in 2. havnt checked fuel injectors or replaced any packs yet. also 99 1.8t b5 preface. Any suggestions on how to test fuel injectors? control module u say??? Hmmm???
Any helps asap will be appreciated. workin on it in the morn.
Thanx
Old Dec 24, 2010 | 08:38 PM
waltma70's Avatar
There is a recall effective for various early 2000's audi coilpacks. There is a design flaw with the head element where moisture can get in and short out the unit causing it to fail.
To confirm it's spark, pull the plugs after the car has been running for awhile and see which one smells like fuel.
If your make/model/year is covered by the recall, the dealership will provide and install the coilpacks for free.
I just went through the motions with my 01 a4. Cylinder 2 was misfiring and the car ran like ****. Call your dealership to see if you are entitled to new coilpacks!!!
Spreading of lore on these forums is terrible.
Old Dec 26, 2010 | 04:51 PM
caodan2010's Avatar
maybe check with ur dealer, cylinder not firing is a big issue
rickyates100
S8
Apr 23, 2015 03:43 PM
2manytickets
Apr 28, 2012 04:45 PM
Auditroubles
Mar 2, 2012 07:59 PM
Wiets
Sep 2, 2011 03:44 AM
qlopp
May 23, 2008 10:51 PM
