A4 1.8 T Possible DV problems
Old Jan 31, 2005 | 07:17 PM
D4rw1n's Avatar
Default A4 1.8 T Possible DV problems
Today I started noticing a strange farting sound coming from the engine compartment. It doesn't happen all the time, mostly when taking off from a stop light. It doesn't seem to happen under high acceleration or at least I didn't hear it. I have only heard under light casual acceleration a few times. I checked around in the engine compartment and did not see anything out of the ordinary. Could this be a sign that my stock DV is starting to leak or could it be something else like a vacuum line? I have a K&N air induction system installed (K&N 57i kit) if that makes a difference. Thanks
Old Feb 1, 2005 | 01:54 AM
D4rw1n's Avatar
Default RE: A4 1.8 T Possible DV problems
*** Bump ***
Old Feb 1, 2005 | 04:10 AM
trailboss's Avatar
Like an actual farting sound or like a ticking or taping rapidy sound. Do you have anything else done to your car?
Old Feb 1, 2005 | 04:19 AM
David_K's Avatar
the K&N would add a loud faucet sound
Old Feb 1, 2005 | 02:35 PM
brrman's Avatar
if it sounds like a goose honk, then its likely the dv.
Old Feb 1, 2005 | 06:49 PM
D4rw1n's Avatar
Well it's not a taping sound. More like what you said brrman a goose sound maybe. Sounds like someone with gas to me, but I guess that could be considered a goose sound. I started hearing it like a day after I installed the air intake kit. The intake kit is the only modification I have. And I'm pretty sure the diverter valve has never been changed.
Old Feb 1, 2005 | 06:52 PM
David_K's Avatar
i think thats just a coincidence. i cant image how a intake could make your dv fail
Old Feb 2, 2005 | 03:58 AM
SlimChriz's Avatar
no I think he means noe that he has the intake he can hear the DV, yes thats normal
Old Feb 2, 2005 | 04:32 PM
D4rw1n's Avatar
Yeah, I don't think the intake made the DV go bad. I'm just trying to make sure that a bad DV is the only thing that can make the goose honk sound when it goes bad, I guess I should have asked this to begin with. I plan on replacing the DV anyway but I want to make sure it isn't something else so I don't replace the DV and still have the annoying honk sound. I know what the air intake sounds like (I'm not referring to the DV dumping into the intake either) just to clear that up.
Smokin Tubes
Feb 5, 2012 10:11 AM
mykien23
Dec 2, 2011 08:55 AM
redrhino
Oct 26, 2011 03:49 PM
commedecargons
Nov 9, 2005 06:43 PM
SamJamaica
Jun 13, 2005 02:07 AM
