A4 1996 idling & throttle issues - please help
Old May 18, 2006 | 12:49 PM
sjamies's Avatar
Default A4 1996 idling & throttle issues - please help
Hi all
Just bought an A4 1996 model, 1.8l manual. Great car, 45k on the clock, good condition. It's just been in to Aud for a full service, cam belt change, brakes, etc. However, even after a full service, it's not idling as it should. Tends to be slightly patchy.
Also, I'm sure it doesn't have the power it should do, it's a bit sluggish when you put your foot down, the acelerator can be a bit unresponsive.
Lastly, when driving in 1st or 2nd gear (in traffic) and the accelerator is suddenly depressed, the car jolts - it doesn't slow down evenly like it should. Even when driving slowly in 1st or 2nd with the accelerator lightly pressed, the drive can be a bit uneven.
Apologies if I'm not making any sense here. If ANYONE has an idea of what could be the problem, PLEASE let me know. I thought Audi would have sorted this out, but obviously not.
Dirty fuel line, accelerator issues, clutch?
Also, in terms of clutch wear - what are the first warning signs of a clutch going? Gearbox clunky when putting it in reverse?
Any help appreciated.
Sjamies
Old May 19, 2006 | 01:06 AM
16w/A4's Avatar
Default RE: A4 1996 idling & throttle issues - please help
try running fuel system cleaner maybe
Old May 19, 2006 | 01:12 AM
spectrum's Avatar
Sounds like repair work problem. Worn clutch slips when driving and if synchros bad will have hard time getting into gear (grinding)
Old May 19, 2006 | 01:25 AM
a4BRZLowrider's Avatar
clutch problemswith only 45k...
"Lastly, when driving in 1st or 2nd gear (in traffic) and the accelerator is suddenly depressed, the car jolts - it doesn't slow down evenly like it should. Even when driving slowly in 1st or 2nd with the accelerator lightly pressed, the drive can be a bit uneven. "
i think thats normal if ur in 1st gear and depress gas pedal and it feels like that...my brothers jetta does that...in 1st gear u hit gas depress and hit again dont matter if hard or slow it seems like the engine is loose and u can feel it kicking...weird....maybe a snub mount for that
Old May 19, 2006 | 01:33 AM
miked's Avatar
ORIGINAL: sjamies
Well..it is a 12v.
That is called engine knocking, it happens if you let off the gas in 1st or 2nd gear in a manual going slowly. And if you get back on the gas its not necessarily smooth. Its totally normal dont worry.
Old May 20, 2006 | 02:32 AM
170 hp aren't that slow bro...thats B/S
Lady Isoult Tibby-Cattistock
Mar 24, 2012 05:25 PM
Alwyn in Trouble
Jun 6, 2011 05:06 AM
audiblacky
Jun 9, 2010 12:46 AM
PappaSmurf
Aug 24, 2009 01:21 PM
