A4 1997 Radio Code, Photo attached!
Old Dec 16, 2006 | 02:44 AM
armanddarke's Avatar
Default A4 1997 Radio Code, Photo attached!
I noticed a member here had posted some information on how to enter the radio code by pressing dx/fm and entering the correct numbers then pressing dx/fm again to confirm. I also noticed on another thread someone said the code should be posted by the spare tire in the trunk, little white square piece of paper sticker with a bunch of the car's information. I checked the trunk and its definitely there but I have no idea which 4 correct digits it is I have to choose. Do any of you guys any idea where exactly I have to look on that sticker that is the correct 4 digit radio code? Maybe you can recognize it, I have attached a photo of that sticker here:
I understand you get only three chances correct?
Also, does the car have to be on or off to activate the code?
Thanks!
Old Dec 16, 2006 | 01:20 PM
dankhound's Avatar
Default RE: A4 1997 Radio Code, Photo attached!
On new cars the code comes on a seperate sticker with the radio serial number on it as well. often times that is removed thou. I never heard of the code being on that sticker but if you want to try go with the 0041. It seems like a plausable radio code. Actually i just saw the 1285 at the bottom. That looks pretty good as well. If i had to guess id say itd be the one at the bottom.
Old Dec 16, 2006 | 03:57 PM
turbo kraut's Avatar
Tech Guru
or go to the dealership and have them pull it
Old Dec 16, 2006 | 11:39 PM
Simone's Avatar
ORIGINAL: turbo kraut
thats what i did..
Old Dec 17, 2006 | 03:50 AM
veloracer's Avatar
I posted the tidbit about the radio info being on a sticker by the spare tire. Got that info from a Livermore Audi salesperson. Since you get three chances to enter the info, there's only two 4-digit codes... you have a 50/50 chance.
Old Dec 17, 2006 | 04:59 AM
I tried the 0041 and the 1285 and pressed the dx/fm to confirm and nothing happened! Not I got two strikes and it won't let me change the code again. What do I do??
Old Dec 17, 2006 | 05:11 AM
BadLuckAudi's Avatar
looks like its time to pull the battery and try again later
Old Dec 19, 2006 | 02:27 AM
dankhound's Avatar
You have to leave the key on for aproximatly 1 hour.
Old Dec 19, 2006 | 04:28 PM
acetrebo's Avatar
ORIGINAL: dankhound
????????????? for what?
Old Dec 21, 2006 | 01:17 AM
dankhound's Avatar
For the radio to reset and allow more codes to be put into it.
