A4 avant 130bhp 1.9tdi idle speed problem
Old May 8, 2007 | 01:28 PM
JeffB's Avatar
Default A4 avant 130bhp 1.9tdi idle speed problem
Hi,
I am new to the forum and having problems with my car. The problem exhibits itself as two symptoms:
1. Random idle speed of 1100rpm (should be 950) happens once or twice a week.
2. No Turboboost ( only occurred once) turn ignition off/on resolves the problem.
Anybody any ideas of the problem, it sound like an engine sensor issue ??
thanks
JeffB
Old May 8, 2007 | 01:37 PM
techbod's Avatar
Default RE: A4 avant 130bhp 1.9tdi idle speed problem
diesels are not my area but it could be the shock absorber on the fuel pump which regulates the idle,
check just below the throttle cable and you will see this little shock absorber which is connected to the throttle linkage as a stabilizer and some folk lean over the engine and snap the end off so it cant be adjusted or hold the throttle at idle, just a guess
Ainzley91
Oct 30, 2013 05:56 PM
manticore1
Apr 11, 2013 06:26 AM
australian_expat
Jun 4, 2010 10:50 AM
swinter
Jan 27, 2010 01:20 PM
vw754
May 9, 2006 08:24 AM
