A4 B5 HID problem
Old Nov 14, 2006 | 01:50 AM
bumperlt's Avatar
Default A4 B5 HID problem
I bought some 6000k HID's to replace the yellowish ones that were in it. I put the new lamps in months ago, and now I am having problems. The left one started to turn off and/or flicker last week, by saturday it was out, and the right one shortly thereafter. Now I did touch the lamps with my fingers which I know your not suppose to do, could that have causes some of the problems? Everything is OEM except for the lamps. So now my wife is driving aorund with just the fog lights until the new lamps get here. Is there anythign I need to check? I hope that it is just the lamps. Thanks!
Old Nov 14, 2006 | 02:30 AM
01A4T's Avatar
Default RE: A4 B5 HID problem
did you do a whole xenon conversion? ballasts, etc? if not, you probably just put in autozone "HID" bulbs into your projectors. i apoligize if i am wrong about you having true xenons, but from my experience, those cheap bulbs at the local auto store burn out quick. and usually touching the bulb applies to halogens.
Old Nov 14, 2006 | 11:22 AM
smokeU's Avatar
if you didnt upgrade the ballasts then you def. need to because your stock ballast will only power 4300K lamps.
and touching the bulbs is a major mistake and is most likely your problem. the oil from your fingers causes hot spots on the glass and makes the bulbs burn out in a few days.
Old Nov 15, 2006 | 12:46 AM
bumperlt's Avatar
I knew I wasn't suppose to touch them, but I didn't know the OEM ballasts couldn't do higher than 4300k. If 6000k burnt them out in 6 mos or so, I wonder how long the new 8000k lamps I just bought will last. Where can I buy an upgraded ballast? Thanks you've been a lot of help.
To the other guy: C'mon I'm not a huge idiot, just a small one.
Old Nov 15, 2006 | 01:06 PM
kraylon's Avatar
i have oem ballast runing 6000k phillips bulbs and i have never had an issue with them doing anything funny
Christopher Nemitz
Mar 12, 2012 09:02 PM
jimc137
Mar 9, 2011 06:48 PM
spyrosg7
Apr 4, 2010 07:48 PM
RIA6
Nov 30, 2006 09:06 PM
