a4 codes needed
hi guys, im a Audi newbie and finding replacing faulty parts not as straight forward as just swapping them out for new ones lol. i brought a a4 2003 2.4 se convertible a few days ago which had been stolen recovered. due to the damage to and around the ignition it needed a new indicator and wiper stalk, steering ring, and of cause barrel, it also had a knock to the front passenger side and needed a abs pump.
i have now replaced all the broken bits and repaired all the damage but have a fair few lights on the dash like a flashing brake warning light, abs light, traction control light (esp), air bag light, and ecl. it also displays a brake warning symbol in the display and says fault in abs system return to workshop when i press the check button.
after doing a bit of searching Ive concluded that they will need to be coded using vag com my question is how do i find the codes or work them out. i need the abs pump code, and steering angle sensor code, i dont think the stalks need coding but i may be wrong.
any help would be much apreciated,
thanks in advance
edds
thanks in advance
edds
