VAG-COM (*New* section) Need some help with a VAG-COM? Have some good advice to offer others using a VAG-COM?
Help needed with Fault codes
Old Jun 5, 2015 | 12:06 PM
torturebori's Avatar
Default Help needed with Fault codes
I ran a scan on my 04 Allroad because the check engine light came on and noticed the car is running a bit different this is what I get
I just don't know where to go from here. Please help
Address 01: Engine Labels: 078-907-551-AZA.lbl
Part No: 4Z7 907 551 R
Component: U25AN34.hex LEV G x
Coding: 07755
Shop #: WSC 02334
VCID: 52AB590F9E8C81B188B-5140
Subsystem 1 - Part No: XXYOUR
Component: VIN HEREXX XXXIMMO IDXXXX
XXYOUR VIN HEREXX XXXIMMO IDXXXX
7 Faults Found:
16515 - Oxygen (Lambda) Sensor B1 S1
P0131 - 35-00 - Signal too Low
16534 - Oxygen (Lambda) Sensor B2 S1
P0150 - 35-10 - Malfunction in Circuit - Intermittent
17536 - Fuel Trim; Bank 1 (Mult)
P1128 - 35-00 - System too Lean
16684 - Random/Multiple Cylinder Misfire Detected
P0300 - 35-10 - - Intermittent
16685 - Cylinder 1
P0301 - 35-10 - Misfire Detected - Intermittent
16687 - Cylinder 3
P0303 - 35-10 - Misfire Detected - Intermittent
16686 - Cylinder 2
P0302 - 35-10 - Misfire Detected - Intermittent
Readiness: 0000 0000
Address 34: Level Control Labels: 4Z7-907-553.lbl
Part No: 4Z7 907 553 F
Component: - 2C1A1 D060
Coding: 25500
Shop #: WSC 02334
VCID: 489F7B6768D03B61E6F-5140
1 Fault Found:
01400 - Suspension Level Control
11-10 - Control Limit Not Reached - Intermittent
Address 35: Centr. Locks Labels: 4B0-962-258.lbl
Part No: 4B0 962 258 M
Component: Central Lock/Alarm D38
Coding: 15885
Shop #: WSC 02334
VCID: 33653C8B0156A8B9A3D-4F06
4 Faults Found:
01374 - Alarm triggered by Terminal 15
35-00 - -
01368 - Alarm triggered by Luggage Compartment Switch
35-00 - -
01562 - Rear right door
59-10 - Can't Unlock - Intermittent
01574 - Alarm triggered by Door Contact Switch; Rear Right
35-00 - -
nikznb
Jan 28, 2014 08:08 PM
EpicA4mike
Nov 10, 2012 06:58 AM
JeePee
Sep 16, 2011 09:29 AM
paulrob2808
Aug 28, 2007 04:18 PM
xxipsxx
Feb 11, 2007 11:16 AM
