A4 Evap and ABS problems
Old Mar 2, 2006 | 04:51 PM
joe_miller01's Avatar
Default A4 Evap and ABS problems
99 A4 2.8 quattro I have seemingly unrelated problems that I could really use some help with.
1) Check engine light with three codes P0455 (evap gross leak), (Yes, the car is turned off when fueling), P1136, and P1138.
2) The engine is slow to light of after fueling and only after fueling.
3)The ABS kicks in at slow speeds with light brake pedal application.
Has anyone experienced these problems and determined the corrective action?
Old Mar 2, 2006 | 05:31 PM
techbod's Avatar
Default RE: A4 Evap and ABS problems
https://www.audiforums.com/m_216897/.../tm.htm#216897
them codes been covered
ABS? does the ABS light stay on or come on when this happens??
Old Mar 2, 2006 | 06:04 PM
No - the ABS system light due not attenuate at any time.
Old Mar 2, 2006 | 07:05 PM
techbod's Avatar
sounds like the bulb has blown or taken out for that reason ABS problem
Old Mar 2, 2006 | 08:34 PM
avanttripleloop's Avatar
if you are not having the hard start/fuelling prob,just try a new gas cap first,abs is same on my car as well as other manufaturers,its never been a problem.mine usually does it when i back uphill out of my drive,put in gear move about 10feet downhill and brake lightly cuz of hill,right then.at start up, all lights should turn on momentarily to signify they are working,check abs light.
Old Mar 2, 2006 | 08:37 PM
miabhai_freaked's Avatar
okk...stupid question...but how does the abs work? i mean...is it on all the time
and in that case how do u activate it? we had about 12 inches of snow today
and the damned car slipped quite a few times...so what do i do??
Old Mar 2, 2006 | 08:47 PM
on but not active until wheel speed sensor tells it to react.sometimes or often my car slips on crosswalk paint when starting from a light.
Old Mar 2, 2006 | 08:54 PM
hmmm...okkk...that's more reassuring i guess...thanks man!
Old Mar 2, 2006 | 09:13 PM
i see the hmmmm,i forgot to say mine is not quattro.
Old Mar 12, 2006 | 07:02 PM
HansBlix's Avatar
I had the same problem today with my 1999 A8 4.2Q - the MIL light came on, and the ABS did too
The ABS light was gone after I immediately drove home to change my underwear. Pulled the MIL light code - its P0455 - checked the gas cap a buncha times, the light is still there (and no, I havent been fueling the car with the engine on).
No noticeable change in car's behavior that I can report, the ABS thing, I suspect, might have panicked at the wet brake pads or something as it was raining(?) Who knows, but its gone.
Taking it to a mechanic tomorrow to diagnose the (alleged) evap control system leak.
lolo22
Aug 13, 2013 06:14 PM
lyosha
Aug 29, 2011 12:09 AM
SrK
Apr 24, 2008 02:16 PM
Karl
Feb 25, 2006 10:52 PM
quattrosedan
Jan 13, 2006 12:21 PM
