A4 Projector Retrofit
Old Dec 20, 2007 | 02:25 AM
Iceman04503's Avatar
Default A4 Projector Retrofit
I have a A4 B5 that comes with factory projectors. I think its time for me to upgrade those. I'm thinking about an Acura TL, RL, or Honda S2000 projector. Which would fit and how would I do it?
Old Dec 20, 2007 | 02:55 AM
01A4T's Avatar
Default RE: A4 Projector Retrofit
no, no, and no.
Old Dec 20, 2007 | 09:11 AM
McGovs2.7TB5's Avatar
Why even think of putting Honda parts on an Audi?
Old Dec 20, 2007 | 09:12 AM
If you really feel it needs the upgrade get some e-codes.
Old Dec 20, 2007 | 09:49 AM
sineo's Avatar
You're talking just about taking the actual lens from the aforementioned headlights and retrofitting them into your own housings? I hope so and I also hope someone chimes in with some good info because I'm interested in that, too.
Old Dec 20, 2007 | 04:55 PM
I'm trying to replace the lens. I was old that the S2000 projector lens is the best out there. I'm just trying to get a better cut off line whats in my car right now.
Old Dec 20, 2007 | 05:46 PM
ImTheDevil's Avatar
Then don't cause yourself the unnecessary work. You have projectors designed to work with the lenses on the headlights. Projectors from other cars are designed to work with the lenses on their housings. Those lenses likely have different angles, and there's a chance that it would skew the beam coming through. Just get HIDs and you'll be happy.
Old Jul 4, 2012 | 03:38 PM
ncmx93's Avatar
This is wrong bro... if you don't know, HIDs shine differently than a normal halogen bulb. Also, the halogen projector is not meant for an HID bulb because halogens do not put out as much light and as wide of an angle as HIDs. This will cause the screwed up cut off line this guy is experiencing.. That means that what he needs is a retrofit. He should look into morimoto they have good designs or also, the Acura TL HID projector is one of the best ones out there. And contrary to what ImTheDevil believes, they will shine just fine through his lenses.
jonet
Mar 21, 2018 11:53 AM
tarapajero1
Jan 9, 2013 09:48 AM
jkainnei
Mar 15, 2008 09:53 PM
mypreludeisred
Mar 14, 2006 04:27 PM
cgv988
Nov 4, 2005 10:13 AM
