A4 Quattro slow coolant level decreasing
Old Jun 28, 2017 | 11:09 PM
Ramudrift's Avatar
Default A4 Quattro slow coolant level decreasing
hello I am new here , I bought a used Audi A4 2006, soon after purchasing within 2hrs I got check engine , I took it back to him, after 2weeks he told he fixed everything but the coolant still loosing levels from trip to trip
i refilled with pentafrost to max , I drove upto 30miles now level came from max to min and the color of coolant changed from pink to a bit black
please help I want to take it back to mechanic
thankyou
Old Jun 29, 2017 | 10:56 PM
rhodes991's Avatar
Doesn't sound good. Check your oil and see if it looks like the same color of a milkshake. From what you wrote it seems like the oil and coolant are mixing. At best it is a blown head gasket at worst it is a cracked block/warped head. None of those are cheap repairs.
Old Jun 29, 2017 | 11:04 PM
Ramudrift's Avatar
i just checked and saw coolant leaking from coolant head, which is below (backside of engine) almost below camshaft chain
and luckly found fix for 200$
Old Jul 5, 2017 | 10:23 AM
rhodes991's Avatar
There is a flange on the backside of the engine (mine was leaking), but I didn't think that would cause your coolant to start turning black. Generally that indicates oil and coolant mixing somewhere (which should not occur at the flange). Hope it resolves your issue for you. $200 is a lot better than $2000!
Cioffie
May 19, 2013 10:24 PM
hartze11
Jan 11, 2009 09:21 PM
Ph3N0m
Oct 21, 2008 12:58 PM
AdilSD
Oct 9, 2008 02:23 PM
jakej
Sep 21, 2008 12:32 PM
