Aaaaaaaand I'm done
Old May 2, 2007 | 03:42 AM
onepoint8tee's Avatar
Default RE: Aaaaaaaand I'm done
ORIGINAL: cyberlogicx
I got me some sweet organic pads because they cost more than regular ones, so they have to be better.
Thats the most ignorant thing Ive ever seen anyone post... You might be right about them being better, but still.. Cost is not always an indicator of quality. What makes them organic anyway??? Are they made of tree bark?
Also, squeeky brakes doesnt necessarily mean your pads are toast. Inspect them, but, Id be more worried about your rotors than your pads. If they are glazed, not even the highest quality pad will help your braking performance. Maybe you should check out some organic rotors... I hear Autozone sells some made out of corn stalks.
Old May 2, 2007 | 03:56 AM
less_of_me's Avatar
[/quote]
lol.[sm=exactly.gif]
Old May 2, 2007 | 08:12 AM
CLX's Avatar
CLX
Zombie Defense Force
ORIGINAL: onepoint8tee
That was also a (apparently) very successful display of sarcasm. I've always used organic pads on all my cars, and it's not because 'they cost more than regular ones, so they have to be better.' I use them because:
1. they last longer
2. they don't make as much dust
3. they have a higher friction coeficient so they are more effective
4. they don't fade as quickly when they heat up
5. and they also bite better when they are still cold
And as far as my rotors go, they are in good shape. Still well within the tolerances (yes, I know how to use a micrometer) and they don't appear to be glazed.
Old May 2, 2007 | 10:43 AM
Amze's Avatar
lol, I thought the exact same thing as I read that comment. Its called doing research and reading reviews and finding the best possible product in a given price range that you have set for yourself. Good luck with your tree bark.
Old May 2, 2007 | 10:44 AM
Amze's Avatar
From what you posted in the beginning... it seemed like you had never used "organanic" brake pads before and now you know everything about them.. I'm confused.
Old May 2, 2007 | 10:55 AM
ironman's Avatar
Cyberlogic where did you get the pads and how much did you spend, my brakes make a terrible amount of brakedust and im thinking of just doing them for the summer so i dont have to do my rims 2x a week.
Old May 2, 2007 | 12:22 PM
CRAZYHAWK's Avatar
Organic pads make the most black dust. They havethe highest coefficient of friction.
Semi-metalic last longer and produce less dust.
Ceramic last the longest and produce the least amount of dust.
Old May 2, 2007 | 12:28 PM
  #18
Amze's Avatar
Lmfao I knew it, I EFFING knew he pulled that out of his **** last minuet to counter his first statement.. sigh sigh
Old May 2, 2007 | 12:51 PM
  #19
CRAZYHAWK's Avatar
Organic pads do bite better when cold, do to greater friction with little
brake force.
Organic pads are soft and wear out faster than semi-metalic and ceramic pads.
They heat up very fast and release the heat with mucho black brake dust.
Old May 2, 2007 | 01:37 PM
  #20
INDEED!
1. they last longer
After a little research...
1. No they dont
2. Yes they do
3. Depends on ambient conditions
4. Possibly
5.Most pads do
