ABS and Break light staying on please help
Old Jun 18, 2006 | 04:29 AM
oziaudi's Avatar
Default ABS and Break light staying on please help
Hi Guy's
Can any of you guru's please help me, My abs and break light are staying on on the instrument panel. When I start the car the light's are off but after about 100 metres they come on. I have checked the pad's and there is plenty of beef on them. I have checked the fuses and they are fine. Plenty of fluid.
Please help
Addam
Old Jun 18, 2006 | 06:43 AM
ejc317's Avatar
Default RE: ABS and Break light staying on please help
vag it?
Old Jun 18, 2006 | 06:59 AM
oziaudi's Avatar
If I buy a vag off ebay what would be the best one to buy please.
addam
Old Jun 18, 2006 | 09:13 AM
ejc317's Avatar
if ur buying just for this ... its a waste - find someone with a vag - there should be a bunch and borrow it
Old Jun 18, 2006 | 02:19 PM
quattrosedan's Avatar
The problem most likely is that your abs module went bad. I have the same problem....but I don't need abs so I am not worried about it. On ebay you can find rebuilt ones for around 200 shipped.
But before buying one, I would make sure that is the problem. It could just be a bad ground somewhere, someone on af had that problem a while back.
Old Jun 18, 2006 | 02:27 PM
S_R_N83's Avatar
ORIGINAL: quattrosedan
^he's right. The abs module is a known problem for Audi. I know many people that it happened to. Use your judgement. Do you think you need it? If so get it rebuilit. (They usually come with a warranty) You could also get a new one from Audi but that will be at least $1000+ for that module.
Old Jun 18, 2006 | 10:07 PM
I believe it was about 1700 when I checked and that is when I realized that I need to just drive a little slower in the rain*.
A4doggy
Jan 30, 2020 09:12 AM
A4doggy
Jan 14, 2012 04:24 AM
Brautty
Jan 8, 2012 05:41 PM
sdsponger
Jun 22, 2009 08:09 PM
blast
Mar 19, 2005 06:55 AM
