ABS lite on and Parking Brake lite beeps and flashes
Old May 23, 2007 | 10:08 AM
Hobo's Avatar
Default ABS lite on and Parking Brake lite beeps and flashes
Recently my ABS lite on my A4 1.8 Turbo Quattro went on. I went and had it check out by my Audi gear heads and it came up as a bad right front brake sensor. They weren't able it fix it that day, so I made an appointment to have it replaced in the next day or two. Two days later not only did the ABS lite say on, but the parking brake lite beeps and flashes. The ABS lite says on and the parking brake lite flashes while driving. I brought it back to the shop, they hooked it up to the computer and know they are getting a "NO ANSWER" read out on the computer....the bad ABS sensor warning did not even show up like it did two days ago. They double checked the brake fluid, but that was fine. Any ideas of what could be causing this problem and how to fix it? Thanks!
Old May 23, 2007 | 12:54 PM
daesharacor's Avatar
Default RE: ABS lite on and Parking Brake lite beeps and flashes
I'm pretty sure that means that your ABS module is bad. This sucks for you, cause they're pretty pricey.
As I understand it, if you connect it to a VAG tool and it tells you the sensor that's bad, obviously it's the sensor... and if it has no response, that means that the ABS module itself is bad.
carguytt987
May 18, 2010 02:13 PM
joeynach
Sep 30, 2009 02:00 AM
il laureato
Aug 18, 2009 11:41 AM
tab667
May 29, 2008 06:27 PM
