abs module
Old Nov 4, 2006 | 07:22 PM
nickt1216's Avatar
Default abs module
Hi, i'm currently trying to take my abs module out to see what my part # is. I took out some screws and this greenish liquid started to leak out, i was wondering if i was suppose to have drain something before hand or am i totally going after the wrong part in my car. If i did go after the wrong part, how do i go and fill this liquid back to normal? Also what kind of liquid is it? What is this part i'm messing around with anyway? Is there a link somewhere with a photo tutorial on how to take the abs module out?
nick
Old Nov 5, 2006 | 02:50 PM
dankhound's Avatar
Default RE: abs module
Thats brake fluid. You will have to add some brake fluid and bleed the brakes. Those lines on the top go to the abs pump. MOst of the time you can leave all that stuff intact when you remove the module. Its held on to the pump by four screws. Its the part that is bolted to the right of the pump. Two of the bolts that hold it on are visable in the picture. The other two are on the lower portion facing the same way as the two on the top.
Old Nov 5, 2006 | 03:04 PM
techbod's Avatar
when you say screws removed are you referring to the coolant expansion tank?? I note its the same coloured liquid as the coolant
[IMG]local://upfiles/12092/22FD5FB3D1B34057950DA9FEE17A311B.jpg[/IMG]
Old Nov 5, 2006 | 05:02 PM
Trey25's Avatar
Unless your removing the hydraulic side of the ABS system you don't have to loosen the brake lines. To remove the electrical side/module follow this...and that doesn't look like antifreeze. I see from the pic you removed the hydraulic line. It's just coincidence that the coolant looks the same. Am I wrong?
Old Nov 5, 2006 | 08:30 PM
CRAZYHAWK's Avatar
You leaked antifreeze. The tank says G-12. Someone filled it with green antifreeze.
You should either use universal yellow or G-12.
nicholec
Aug 25, 2015 01:14 PM
stang32
Feb 23, 2014 10:53 AM
mtngirl
Sep 1, 2009 05:37 PM
phillyfannc
Jun 1, 2007 02:38 PM
ddd
May 26, 2007 08:51 AM
