Sponsored by:
Sponsored by:
ABS and Traction control lights on
Old 07-17-2014, 06:19 PM
Yamaha822's Avatar
Default ABS and Traction control lights on
I just recently bought a 2002 audi a4 1.8t quattro 5 speed manual and Today on my way to work the abs and traction control lights came on about 10 miles into the trip. Any ideas as to what this could be? the brake light is not on or flashing in the dash; dont know if that helps at all. Thanks.
Old 07-20-2014, 02:24 PM
magicturtle2's Avatar
sounds like an ABS speed sensor is out. I just changed one of mine on the right front. Its fairly easy and the sensors are not that expensive. I would check all four tires for any visible damage to the sensor wires etc. and go from there. With any luck you will be able to see the problem.
chucks6
06-14-2012 07:33 PM
DÌEGØs AÜD!CTIØN
01-22-2009 07:12 PM
bornnation29
03-08-2008 09:22 PM
3phil4
02-11-2007 09:19 PM
tholman
08-14-2006 03:35 PM
Quick Reply: ABS and Traction control lights on
