pad wear sensor connector
Old Jul 13, 2014 | 05:38 PM
pinman's Avatar
Default pad wear sensor connector
hi, a bit of a noob question but having a problem after trying to install new brake pads to my 2002 tdi b6.
Issue is the stupid pad wear sensor connector won't clip back in properly! when i took old pads out it was simple as, just pop screw driver in the tab to release and it just slipped out.
With new connctor (or even the old one from removed pad) no matter how hard i press it won't clip in properly, even with screw driver to force up the clip etc... To be water tight there is a rubber seal and it's as though when i press the trapped air compresses and won't let it go back in. I've tried some grease to let it slip back in but no help.
Any tips please??
Old Jul 20, 2014 | 02:27 PM
magicturtle2's Avatar
Check to make sure there isnt anything stuck in the connector limiting how far in it will go. Thats all I got.
Jole2003
Jan 24, 2015 12:37 PM
sadik666
Jul 31, 2014 12:40 PM
brknhalo
Mar 6, 2014 08:55 AM
BillyTuttle
Oct 8, 2013 02:33 PM
caymancop
Sep 15, 2011 11:57 PM
