AC Belt Removal Help
Old Nov 21, 2006 | 12:33 PM
barrios35's Avatar
Default AC Belt Removal Help
Is there a special tool to get into the AC belt without removing the bumper? I can't get the torx driver in to loosen the pulley for th AC belt. My serpentine belt is shot but the AC belt needs to come off for the serpentine to slide out of the crankshaft. It does not need the timing belt yet. Any tips? I need to get this done asap.
Old Nov 21, 2006 | 12:43 PM
techbod's Avatar
Default RE: AC Belt Removal Help
its called a spanner 15mm special tool 1, age of car engine cc might help
Old Nov 21, 2006 | 01:35 PM
barrios35's Avatar
Sorry... 2001 A4 1.8T FWD. So with this tool I can remove the AC Belt from the car without removing the bumper.
Old Nov 21, 2006 | 03:23 PM
acetrebo's Avatar
You can, just need to carefully choose tools that will fit.
I ran in to the same probelm last night, I had to remove the AC compressor to get the starter off. I had a heck of a time with that pulley, in fact, I ended up just loosening the compressor and getting the belt off that way.
You need a 6mm hex I believe, and a wrench that will fit in there! I was about to use a hex wrench, but got it off the other way instead.
Old Nov 21, 2006 | 05:31 PM
barrios35's Avatar
I was looking at sears for the micro wrenches. I tell you they sure make things complicated now a days. The serpetine belt comes off with ease. Not sure why they needed to complicate the AC Belt... How hard was the compressor to move?
Old Nov 21, 2006 | 05:49 PM
acetrebo's Avatar
ORIGINAL: barrios35
Not bad really. 4 bolts, and swing it out of the way. I spent way more time trying to get the wrench out of the tensioner bolt than I did removing the compressor.
Old Nov 21, 2006 | 06:00 PM
barrios35's Avatar
I think that is going to be the route I take... Thought I might be missing some mechanic trick with the pulley removal.. Thanks for all your input.
brian58503
Aug 13, 2014 06:05 PM
KEVBASA6
Oct 14, 2013 07:18 PM
tacu21
Mar 28, 2005 05:12 PM
