Accelaration Problem-Help Help
Old Mar 1, 2007 | 12:32 AM
Hove_06902's Avatar
Member
Default Accelaration Problem-Help Help
I have a 2000 A4 1.8T and I been having problem with accelaration while driving.The problem is when I step on the gas pedalthe car doesn't move right away, as matter fact it takes about a seconds for the car to move. And sometimes while driving on the highway whenI press hardon the gas I hear a growling noise on the engine, and then the car start to pick a little speed. Everyone Just try to understand I'm don't have a racing carbutmy carholds back for afewsecondsinstead of going fast when I press the gass pedal that's the problem. So if anyone can give me some suggestions on how to fix the problem I would appricate it very much. Also the car is not chip, so I don't expect to move as fast as a ferrari but I put too much pressure on the gast for it to move that's my concern.
Thanks.
Old Mar 1, 2007 | 12:41 AM
AML 225's Avatar
Default RE: Accelaration Problem-Help Help
Can't be sure for sure but I believe the problem you are describing is called TURBO LAG. Get use to it.
Old Mar 1, 2007 | 01:51 AM
Amze's Avatar
It's not turbo lag.. once he hits 3k it takes off, and is very noticable...
I think theres a possibly a bad DV or a leak? Are there any unusual sounds? I'd replace the Diverter Valve for 35$ first.
Old Mar 1, 2007 | 02:03 AM
A4Rollin's Avatar
he said there was a "growling noise" when he hit the gas. There has to be some type of leak where pressure is seaping out of it
Old Mar 1, 2007 | 02:21 AM
Hove_06902's Avatar
Member
Where can I get the Diverter Valve for $35? The website would be helpful.
Thanks.
Old Mar 1, 2007 | 03:19 AM
Hove_06902's Avatar
Member
Old Mar 1, 2007 | 06:04 AM
Audi_Skydiver's Avatar
Go to your local audi dealership and aske them for the 710N DV valve.
Josh
Old Jan 6, 2008 | 11:51 PM
naterta's Avatar
I am having the same problem but w/o any noise. could it still be the dv?? any help would be great.
Old Jan 6, 2008 | 11:52 PM
naterta's Avatar
btw its a 03 A4 1.8T if that helps.
abodh
B7 Models
Jul 10, 2011 10:37 AM
xzera
Sep 16, 2010 10:43 PM
spyrosg7
Apr 4, 2010 07:48 PM
tommygn
Feb 25, 2006 12:11 AM
