air box removal
Old Jul 26, 2006 | 05:24 PM
impaler2383's Avatar
Default air box removal
Stuck. Where do I go from here to remove air box? Not sure which hoses are talked about in the audiworld DIY
Old Jul 26, 2006 | 06:01 PM
Default RE: air box removal
also, what's this special 3 pronged tool that I need for hose at bottom of pic? anyone have more info?
thanx
Old Jul 26, 2006 | 06:15 PM
a4autocrossr's Avatar
what.....?? the large hose (bott right)...un screw the clamp but not all the way...just enough to slide it off...also slide off the hard plastic hose to the left of that....there are 3 clips holding the upper part of the box to the lower...unclip those....pull all wires over top of box...flip cover over onto engine cover...remove filter...unbolt on left side bolt holding box to car frame...remove box....cut hole...cut holes in fender....place screen over holes with 2x side tape....reverse process....
--E
Old Jul 26, 2006 | 06:20 PM
smokeU's Avatar
to get the top off reach down around edges and unclip all of the little medal clips holding the top to the bottom. 4 i think. unscrew clamp holding large hose on and pull off. pull off little hose comes right off with a little muscle. shouldnt need a special tool. unplug maf. wiggle top of box out around all of the wires lines etc. should be a little tricky but you can squeeze it.
then look to the left theres a bolt on the inside of the top of the front fender. unscrew that and you can take the whole bottom of the box out. shouldnt be anything else holding it in there.
just take your time dont want to tear any wires or hoses. hope this helps a little.
Old Jul 26, 2006 | 07:01 PM
thanx man, just wasn't sure. that wasn't too hard
not gonna do the box mod yet.
Soley4pres
Jul 11, 2011 11:58 PM
99a4wagon
Dec 10, 2010 07:03 PM
halfmoonclip
B8 Models
Jan 9, 2010 09:48 PM
nhltfour
Apr 22, 2007 02:23 AM
MeanAudiA6
Aug 6, 2006 04:57 PM
