airbag light
Old May 22, 2004 | 06:35 AM
yoon's Avatar
Default airbag light
is there any free ways to turn off the airbag light in the dash? if not then, how would i be able to do it? thanks
Old May 23, 2004 | 09:59 PM
Jestnomen's Avatar
6th Gear
Default RE: airbag light
Could be one of several things. Check too see if the wiring connectors under the seat are all connected right. It could also be the connecters on the actual airbags themselves. I'm going to guess that the light won't extinguish without using a Vag-Com to clear the fault code(s).
If you really don't care about safety and just want it gone, you could remove your instrument cluster and pull the light bulb out. I wouln't recommend that though.
Old May 24, 2004 | 12:10 PM
hb972.8q's Avatar
i hav a vag com and it says to realy stay away form the airbag system. i would just bring it to the dealer. it will cost you tho
HolyokeAudi
Dec 17, 2014 09:13 AM
pologoped2
Jul 28, 2013 05:47 PM
v8_ranch
Aug 27, 2012 12:45 AM
Niclipse
Apr 11, 2011 05:29 AM
geoff4
Feb 22, 2006 04:01 PM
