Airbag Light On but cleared
Old Oct 25, 2006 | 08:12 PM
Ford2Audi6's Avatar
Default Airbag Light On but cleared
The other day I changed the oil in my car and after I was done parked it for the night and next morning airbag light came on. I scanned it with an OBDII and the code came up 01218 (unknown component, value of resistance too great). I cleared the code and it never came back on. I'm guessing I am good and my airbag system is in operation. I was told that the passenger seat has connectors underneath and they might have become loose. My question is do you think I should let everything be because the light is on or look for a loose connection. And even though I cleared the code and the light came back on is the system fully operational? I just want to make sure my airbags will deploy if needed. By the way I drive a 1999 a4 qm.
Old Oct 25, 2006 | 11:21 PM
Ford2Audi6's Avatar
Default RE: Airbag Light On but cleared
bump, anyone have any input?
Old Oct 26, 2006 | 03:02 AM
dankhound's Avatar
There are connectors under both front seats that have intermitant high resistance for the side airbags. You can try using a contact cleaner on them. There was also a tech bullitin to rewire out the connector but im not sure if it applys to your veicle.
How long does it take for the code to pop up? If its almost imediatly there is a problem with the system and at least that one part will not function in an accident. If it takes a while, the sytem is most likely ok and the system "should" operate as designed.
Old Oct 26, 2006 | 09:17 AM
MC Hammered's Avatar
If your airbag light is on then NONE of the airbags in the car will be deployed in an accident.
I'd check the connectors to make sure they aren't loose or have a bad connection.
Old Oct 26, 2006 | 12:04 PM
CRAZYHAWK's Avatar
Have it scanned with a VAG-COM or VW/Audi specific code reader.
Old Oct 26, 2006 | 04:48 PM
Ford2Audi6's Avatar
thanks for the input guys. Ever since I cleared the code it hasnt come back on. I think it was set off because of when I moved the seat back a little too hard. But what will the vag com tell me that the obdII didnt???
Old Oct 26, 2006 | 06:13 PM
The VAG might have a better description of the code vs the OBD2 scanner.
But as long as the light doesn't come back on you are fine.
Old Oct 26, 2006 | 07:40 PM
Ford2Audi6's Avatar
Thanks MC, I guess I might need to get a hold of a Vag
HolyokeAudi
Dec 17, 2014 09:13 AM
pologoped2
Jul 28, 2013 05:47 PM
v8_ranch
Aug 27, 2012 12:45 AM
Niclipse
Apr 11, 2011 05:29 AM
geoff4
Feb 22, 2006 04:01 PM
