ALL THE DV INFO YOU NEED
Old Jul 7, 2007 | 03:41 PM
JettaRedII's Avatar
Default RE: ALL THE DV INFO YOU NEED
ORIGINAL: Jeff
when i turned my dv around backwards it held 2x as much boost. i ran it on my t3t4 for a long time pusing 25psi
Well, if it was holding only 12.5 psi in the standard position, it was probably defective/broken to begin with.
Old Jul 10, 2007 | 12:31 PM
Jeff's Avatar
Zombie Defense Force
no it was holding fine but i went from 7-9psi in the ko3 turbo then put the t3t4 in and turned the dv around and ran 25.
Old Jul 15, 2007 | 06:37 PM
cincyTT's Avatar
I'm make believe
according to Bosch, the 710 should be with the pressure to the side if preintercooler and from the bottom post intercooler. I thinka solid dv (not weak diaphram like the 710) should be placed with the pressure side down, over the boost (not on the intake), and close to the TB. This puts less heat on the valve, keeps the turbo spinning faster between shifts, releases air faster and more air overall.
Also throwing this in, i have flipped the stock dv around when it started to fail and it held boost better along with several other TT and 1.8t owners
Old Jul 16, 2007 | 03:51 PM
98jeep5nine's Avatar
am i understanding this flipping the DV around to hold better boost?
what is "around"?
Old Jul 16, 2007 | 04:47 PM
cincyTT's Avatar
I'm make believe
the side that was on the intake is now over the pressure and vise versa. I would only do it with a dying 710 and thats it unless you run a bov/hybrid or move the dv post ic.
Old Jul 16, 2007 | 11:33 PM
how do these things die? theyre so simple haha
Old Jul 16, 2007 | 11:36 PM
cincyTT's Avatar
I'm make believe
the diaphram cant take the heat and pressure. They make it expand and contract until they cant take it anymore and tear or worp
Old Aug 17, 2007 | 12:57 AM
  #18
apr_a4's Avatar
i cant wait to instal apr r1 valve i just purchased.. now this going to sound stupid i cant find the stock valve on my b5 a4 quattro to switch with
btw i purchased a carbonio intake for my car that was a snap to install but the dv is killing me can any one help
Old Aug 17, 2007 | 06:30 AM
  #19
Matt_Iliketurbopull's Avatar
I'll be probly buying the R1 by APR. its supposed to have all the benifits of a diaphram type, without wearing out.
Old Aug 17, 2007 | 09:05 PM
  #20
Jeff's Avatar
i want to hear more people running that valve. it sounds like its going to be great.
