all warning lights on dash are on??? HELP!
Old Aug 10, 2007 | 08:06 PM
njtrackstar's Avatar
Default all warning lights on dash are on??? HELP!
I have a 98 a4 2.8Q with tip,full milltek exhaust, intake, and chip. The check engine light,airbag,abs,break - are all on. What could it be fuse? If i take the car to audi would they be able to vagcom it out? Thanks for your help in advance.
mike
Old Aug 10, 2007 | 08:31 PM
Borden's Avatar
Default RE: all warning lights on dash are on??? HELP!
you could take it to autozone and they can read the codes for you for free
Old Aug 10, 2007 | 09:06 PM
has anyone else ever had this happen? if so what was the cost to have it corrected?
Old Aug 10, 2007 | 09:47 PM
01A4T's Avatar
yeah, you should deff. take it to an autozone to get it scanned.... it takes about 1 minute, its free and you will get codes to give us so we can try to help you...
Old Aug 11, 2007 | 12:46 AM
acetrebo's Avatar
No, no one has ever had this happen. But if they did it would cost them around $1,237.
Old Aug 11, 2007 | 12:55 AM
onepoint8tee's Avatar
ORIGINAL: njtrackstar
vagcom it out?
Nice.
Old Aug 12, 2007 | 02:12 PM
widlcats's Avatar
your abs and e brake lights could be a abs module. i had that hapen.
Old Aug 12, 2007 | 02:40 PM
techbod's Avatar
the airbag is the odd one out so check if the battery is good and if the alternator is not putting too much power out, I have seen this happen and it was the alternator over charging the battery and it burned all the dash system out due to over voltage surge
Old Aug 12, 2007 | 10:35 PM
widlcats how much did that set you back to have it fixed.
Old Aug 14, 2007 | 10:59 PM
avant80- the battery is fine. its3/4th of the way up the guage when the car is started (not sure if thats normal)?
EugeneTakoev
Sep 7, 2013 10:34 PM
Oddy Ay Fore
Nov 27, 2012 10:20 PM
Willrwilli
Jan 4, 2010 10:05 AM
rmac.cab
Oct 17, 2007 02:21 AM
OptimoCynic
Jan 27, 2007 02:47 AM
