Amp Install. Tapping directly into stock amp
Old Mar 4, 2007 | 04:18 AM
banderson121's Avatar
Default Amp Install. Tapping directly into stock amp
I have read all the forums on installing an amp in a b6 and I still dont know exactly how to do it. I want to tap directly into the stock amp through the rear speaker outputs but im not sure how to. Do I use a male or female RCA wire when I splice the rear output wires? Also I talked to the guy from a4mods.com and he said to tap the RCA wire directly into pins 7 and 8 on the stock amp (left and right rear outputs) with a ground for each. Is a ground for each necessary. If so how do I ground an RCA wire??
Old Mar 4, 2007 | 04:29 AM
akielb's Avatar
Default RE: Amp Install. Tapping directly into stock amp
Your amp has to have speaker level inputs for you to hook up an amp to the speakers. its that simple - you don't splice in your RCA's to the speaker wires. You'll have to research on your amp if it is possible.
Crutchfield info
Old Mar 4, 2007 | 04:41 AM
I havnt bought an amp yet so could you suggest one that would work with this setup?
Old Mar 4, 2007 | 04:48 AM
akielb's Avatar
what setup - all I know is that you hooking up an amp. What are you doing - speakers, subs, mono channel, 2,4 channel how much power are you looking for etc?
Old Mar 4, 2007 | 04:49 AM
I want to power mytwo12 inch sony explod subs. they run at 300 watt rms
Old Mar 4, 2007 | 04:58 AM
How about the Apline MRP-M450?
Old Mar 4, 2007 | 05:02 AM
akielb's Avatar
Getting to late - I'll look around a little tomorrow - I would suggest going with a kenwood amp that puts out about what power you need. how much money are you lookin to spend?
Old Mar 4, 2007 | 05:06 AM
I was thinkin about gettin one off ebay for like 300. Ill look around at amps keeping in mind that I need to get one with the speaker level inputs. Thanks a lot for your help
txhorns281
Aug 12, 2008 08:29 PM
Pablo_Ottawa
Jul 8, 2007 12:44 AM
Indiepunk
Apr 26, 2007 02:25 AM
