Amp Wiring
Old Mar 20, 2006 | 10:21 PM
north5995's Avatar
Default Amp Wiring
So I have my amp wired up, the power from the battery to the amp, grounded, tapped the speakers as in this DIY: http://www.audiworld.com/tech/elec29.shtml
If I connect everything together, I get feedback and poping in my speakers. This has been so frusterating.
So... could this be:
a) grounding issue
b) amp bridging issue
c) you tell me...
Yeah im useless when it comes to wiring.
Old Mar 20, 2006 | 10:28 PM
Jestnomen's Avatar
6th Gear
Default RE: Amp Wiring
Might want to go buy a ground loop isolator from best buy's car stereo install guys. It took care of my dirty sound problems when I installed an amp in my B5.
Old Mar 20, 2006 | 10:32 PM
north5995's Avatar
I'll look into one of those... how much do they cost?
I am actually having consistent popping noises when I plug everything in...
Old Mar 20, 2006 | 10:35 PM
Jestnomen's Avatar
6th Gear
Maybe 10-15 bucks. Just a little box that plugs inline with the RCA patch cables. You didn't by chance run the Power wire right next to the RCA did you?
Old Mar 20, 2006 | 11:41 PM
north5995's Avatar
Nope.
What I did was ran the power wire down the driver side of the car.
Then I tapped into the rear left speaker (where the speaker amp is) into the low level input (before the plug). I tapped the switch on/off, right and left, ground all like this article on AW said: http://www.audiworld.com/tech/elec.html . I spliced a set of RCA cables (RCA end into my amp) and the others tapped the wires from the HU.
I am actually getting feedback through my rear speakers not only my amp. So I am wondering if maybe the tapping is the problem.
Hope this information helps.
Old Mar 20, 2006 | 11:57 PM
BFlan2001's Avatar
because of the speakers' common ground, you need to install a ground loop isolator...i did the same install (except for the bose) in my car and when i was done i had all kinds of crazy interference, mostly from the alternator...a ground loop isolator is about 15 bucks on ebay, probably only a few bucks more at best buy...that should completely kill the interference you're getting
Old Mar 21, 2006 | 12:15 AM
north5995's Avatar
Thanks a lot guys, I'll give it a try and let you know.
vtraudt
Oct 10, 2013 01:33 PM
audi908
Mar 11, 2010 05:42 AM
tmanley
Aug 26, 2009 10:58 PM
Mya4T
Oct 23, 2007 06:15 PM
highbeam
Jul 19, 2006 11:18 AM
