Amp Wiring
So I have my amp wired up, the power from the battery to the amp, grounded, tapped the speakers as in this DIY: http://www.audiworld.com/tech/elec29.shtml
If I connect everything together, I get feedback and poping in my speakers. This has been so frusterating.
So... could this be:
a) grounding issue
b) amp bridging issue
c) you tell me...
Yeah im useless when it comes to wiring.
a) grounding issue
c) you tell me...
Nope.
What I did was ran the power wire down the driver side of the car.
Then I tapped into the rear left speaker (where the speaker amp is) into the low level input (before the plug). I tapped the switch on/off, right and left, ground all like this article on AW said: http://www.audiworld.com/tech/elec.html . I spliced a set of RCA cables (RCA end into my amp) and the others tapped the wires from the HU.
I am actually getting feedback through my rear speakers not only my amp. So I am wondering if maybe the tapping is the problem.
Hope this information helps.
because of the speakers' common ground, you need to install a ground loop isolator...i did the same install (except for the bose) in my car and when i was done i had all kinds of crazy interference, mostly from the alternator...a ground loop isolator is about 15 bucks on ebay, probably only a few bucks more at best buy...that should completely kill the interference you're getting
