anti lock brake problem in 2001 A4
Old Feb 11, 2007 | 10:12 PM
mmort22's Avatar
Default anti lock brake problem in 2001 A4
About three months ago I changed the brakes on my A4 and now for about the last two weeks the anti-lock brakes have been coming on for regular stops and not just when needed. It is not happening all the time and typically only happens as the car gets under 10 MPH. Has anyone experienced this with their Audi and/or does anyone have any ideas of what the problem could be?
Any help/advice/acknowledgement would be appreciated!
Old Feb 12, 2007 | 04:44 PM
sirfalconx's Avatar
Default RE: anti lock brake problem in 2001 A4
It could be the ABS Sensor, its very expensive to fix too... I HATE ABS so I pulled the fuse and just deal with the christmas lights...
Old Feb 25, 2007 | 10:50 PM
mmort22's Avatar
After completely taking the breaks apart to see if we could see anything wrong with them (we didn't) the problem was still there so I did as you advised and I pulled the fuse as a temporary solution. After we did that thecar would not start with the engine just turning over and not catching.
Any further thoughts and ideas would be appreciated? Thanks!
Old Feb 26, 2007 | 11:32 AM
sirfalconx's Avatar
Hmm maybe something is different on the 2001 models... Maybe there is a different way to disconnect the ABS sensor on newer models? anyone?
Old Feb 26, 2007 | 12:52 PM
techbod's Avatar
only 1 fuse I can see and its #17 but as its only happening now and the at low speed it sounds like the (BBP) break pedal position sensor code 00526 if you have VAG
Old Feb 26, 2007 | 12:54 PM
techbod's Avatar
some pictures before you ask
[IMG]local://upfiles/12092/F0ACBBA048B84A3D8BA9A516EB2BE1A2.jpg[/IMG]
[IMG]local://upfiles/12092/23993FE9A6024A839D7AA5E848078312.jpg[/IMG]
Old Feb 26, 2007 | 02:42 PM
SAudi's Avatar
ORIGINAL: sirfalconx
dosent that also ake out your EDL since it works in conjuction with your ABS
blizzdee
Jun 10, 2012 05:24 PM
artracer
Jul 20, 2008 03:26 PM
dasilm525
Jun 26, 2007 12:54 PM
mloftis06
Dec 29, 2006 03:04 AM
murphy_boy_2
Oct 31, 2006 07:17 PM
