Antifreeze
Old Nov 26, 2007 | 01:38 PM
ballswell's Avatar
Default Antifreeze
Coolant light popped on, and I noticed the tank if full of water. I bought some antifreeze, but not sure the best way to get the water out of the tank. Is there a drain valve somewhere that I'm not seeing? On my lunch break, so didn't have a long time to fiddle with it. Any advise is appreciated, thanks.
Old Nov 26, 2007 | 01:56 PM
SAudi's Avatar
Default RE: Antifreeze
uh i think you should be asking why the tanks full of water, anyways the only real way to drain it is take the bumper off and twist the red drain plug, or you can just take off one of the hoses and drain everything in like 10 seconds, if you just need to drain water in the tank just unclamp the hoses and drain it that way but you will most likely end of spilling some coolant in the system.
Old Nov 26, 2007 | 02:29 PM
chaos92287's Avatar
you cant put any old anti-freeze in. universal yellow can work but not the green stuff. but NONE of these should be mixed with g12, which is what should be in your car. it should be a mix of g12 and water bout 50/50. as for draining the water, there's a plug on the bottom right of the radiator. i had to take my grill out of my s4 bumper to get to it. should be red, but might be black. you just unscrew that and all the coolant will pour out.
and if your coolant light is going on but the expansion tank is full it is most likely your ECT
A4 Neil
Oct 10, 2011 03:39 AM
Tullybeagles
Dec 7, 2010 03:37 PM
anmagro
Nov 3, 2008 10:42 AM
LeAudi19
Jul 27, 2008 06:37 PM
blast
Mar 12, 2005 11:20 PM
