Any opinion on which turbo timer to buy?
Old Mar 4, 2007 | 09:06 PM
Belligerenceā„¢'s Avatar
Default RE: Any opinion on which turbo timer to buy?
ORIGINAL: A4nicator
If youre not running to turbo to above normal operating temperature, meaning your not really honing on the turbo, then its really not necessary to give it ample time to cool down. If you beat on it, sit and let it cool down a little. If you drive it normally, i.e. not going about 4k, then you wont have to allow for a cool down period.
for the most part, yes that is correct. however, I wouldn't base your estimation of how much you're bagging on your turbo on RPM's alone. our cars can make full boost, and maximum torque, very low in the RPM range. if you're driving it under half throttle or more, you're heating up the turbo enough to the point where you should let it cool before you turn off the engine. if in doubt, let it cool down a bit. you'll be better off in the long run.
njtrackstar
Mar 12, 2009 09:22 PM
theguy1084
Jul 8, 2007 11:56 AM
im.a.real.vegetarian
May 13, 2007 06:59 PM
funjuice
May 12, 2007 05:01 PM
khj677turbo
Nov 3, 2006 03:56 AM
