Anyone know what this is?
Old Mar 6, 2007 | 12:07 AM
Belligerenceā„¢'s Avatar
Default RE: Anyone know what this is?
ORIGINAL: ThePaintballGuy
ORIGINAL: Belligerenceā„¢
that looks like an intercooler to me too, but did audi move it to the passenger side on B6's?
I was wondering the same thing. On my B5 it's on the drivers side.
Can you get more pictures of it??? And of whats around it???
Josh
mine too, that's why I was confused. yeah, more pics (perhaps with something other than a camera phone ) would help a lot.
Old Mar 6, 2007 | 01:23 AM
M„§T's Avatar
lol....Yea, that looked like the intercooler to me. its metal, with a plastic top, which has an iron pipe coming out of it. It is on the plastic that the gauge tube is located. Is there anyway someone else with a B6 could look at this (or you could probably just feel it, while the engine is cold, by reaching under the passenger headlight) to see if there is anything like this on their car. If there is no other reason for this other than the boost gauge, I am going to remove it and seal off the hole, and connect the boost gauge to the intake line like it should be.
p.s. I will try to get better pics tomorrow.
Old Mar 6, 2007 | 01:26 AM
turbo kraut's Avatar
Tech Guru
just seal it and put the boost guage where it needs to be anyways
Old Mar 6, 2007 | 09:42 AM
M„§T's Avatar
I think I'm going to. But I would like to know if something actually goes there....to me it doesn't look like that is the case but I want to make sure.
ORIGINAL: turbo kraut
Old Mar 6, 2007 | 12:38 PM
kpatz's Avatar
The intercooler on a B6 is on the driver's side too. I'm not sure, but I think that tube is the one going from the turbo to the intercooler.
Old Mar 6, 2007 | 12:45 PM
Hey_You's Avatar
That's the fuse to the bomb in your tubing, don't mess with it, or you will blow up!
Old Mar 6, 2007 | 01:26 PM
M„§T's Avatar
That's what it looked like to me, but that is the passenger side of the car. You can see the airbox in the first picture.
ORIGINAL: kpatz
Old Mar 6, 2007 | 01:35 PM
  #18
SacTown_Vlad's Avatar
by the way where you should install/plug your boost guage?
Old Mar 6, 2007 | 04:52 PM
  #19
kpatz's Avatar
ORIGINAL: M„§T
That's what I meant. The IC is on the driver's side but the turbo is on the passenger side. Therefore, there is a tube (or probably more correctly, a pipe) that runs across the front of the engine connecting the turbo outlet to the intercooler. Assuming I'm correct (and that's a big assumption as I don't have my head stuck under the hood of my car right now) the boost gauge is presently connected to this pipe near where it connects to the turbo outlet.
Can you follow that pipe and see where it goes? Maybe take some more pics?
The two common places to hook up a boost gauge is on the vacuum line going to the wastegate controller or the one going to the fuel pressure regulator. Do a search, there are plenty of write-ups showing the proper locations.
Old Mar 6, 2007 | 05:00 PM
  #20
A4nicator's Avatar
looks like some sort of o2 to me.
