anyone know what these codes mean ?
Old Aug 12, 2005 | 08:26 PM
brent07's Avatar
Default anyone know what these codes mean ?
i got my codes from the computer the other days and they were as followed
p0455 : somthing about a evaporator circuit leak ? how do i fix this ?
01217 & 00589 ? any ideas ? thanks alot ....
Old Aug 12, 2005 | 10:14 PM
CRAZYHAWK's Avatar
Default RE: anyone know what these codes mean ?
P0455 Evaporative emission control system, large leak detected. Check your gas cap.
Do the other codes staat with a "P" ?
Old Aug 12, 2005 | 10:31 PM
brent07's Avatar
no i dont believe so ... they were just as shown ... i know the guy used a determinator scan system ? ... i dont know if that makes a diff .... the gas cap is on ... i think its leaking a little oil is the problem ...
Old Aug 12, 2005 | 10:49 PM
david9999's Avatar
01217
Side Airbag Igniter, Driver's Side-N199
Resistance value too small
Short circuit in wiring
Side airbag, driver's side faulty
Airbag control module -J234- faulty
- Repair wiring according to wiring diagram.
Electrical Wiring Diagrams, Troubleshooting & Component Locations binder
- Replace side airbag, driver's side
- Replace airbag control module -J234-.
00589
Airbag Igniter 1-Passenger Side-N131
Resistance value too large
Open circuit in wiring
Passenger-side airbag unit faulty
- Replace passenger-side airbag unit.
00589
01-17
DTC
VAG 1551 scan tool display
Possible cause
Corrective action
00589
Passengers side airbag igniter 1 -N131- Short circuit to B+
Wire damaged
Airbag control module -J234- malfunctioning
00589
Passengers side airbag igniter 1 -N131- Short circuit to Ground
Wire damaged
Passenger-side airbag unit malfunctioning
01-18
V.A.G 1551 print-out
Possible malfunction cause
Corrective action
00589
Igniter 1 for airbag (passenger's side) -N131
Short to Ground
Wiring damaged
Front passenger's airbag unit faulty
Airbag control unit -J234 faulty
- Repair per wiring diagram
- Replace front passenger's airbag unit
- Replace airbag control unit -J234
Old Aug 12, 2005 | 11:15 PM
brent07's Avatar
thanks alot ... i'll take a look at it !
markymarc
Sep 8, 2010 01:59 AM
joenelson7687
Aug 25, 2010 04:10 AM
Ruggedboy
Jul 20, 2007 11:30 PM
supercoupe91
Jul 13, 2007 06:20 PM
rafa_207
Jun 27, 2007 01:31 PM
