Apr 1+ dyno w/ tiptronic
Old Aug 21, 2007 | 01:54 PM
crd945's Avatar
Default RE: Apr 1+ dyno w/ tiptronic
I mean no disrespect by questioning a member with a million posts, but if someone is wrong, they are wrong
Old Aug 21, 2007 | 02:01 PM
crd945's Avatar
I think you should call it a day. I am talking about B6 A4's. NO COMPANY, NOT GIAC, NOT APR, NOT REVO, uses fuel pressure regulator.s So no, Giac does not use a 5 bar one. People often use Genesis 380cc injectors with GIAC FXk03 and a lot of people use tt 255 injectors (386cc) with APR and REVO 1+.
And no, I make more power than they do on their injectors.
245hp / 275 ft/lbs or torque is stated on the APR website without a FMIC or Exhaust. You do the math.
To Sum up
My car (245hp) > tt 225(225hp)
***I am not claiming my car will win a race or even be faster, I am simply stating numbers!***
On b6 a4's NO FUEL PRESSURE REGULATORS are to be added (on giac, apr or revo)
Old Aug 21, 2007 | 02:05 PM
crd945's Avatar
Will someone with a 2002 + a4 please chime in here and teach him a lesson because he certainly isnt listening to me.
Old Aug 21, 2007 | 02:10 PM
cincyTT's Avatar
I'm make believe
You are STILL missing the point. Your turbo is MAXED OUT. Will not more power by running more boost. The 225 isnt even at 1bar yet. A chipped 225 will run 22psi and with a full turbo back will make ~220Awhp on the same injectors and at 3bar compared to you with your maxed out turbo at 4bar (meaning you are running more fuel). I so hope this is sinking in.
Old Aug 21, 2007 | 02:12 PM
crd945's Avatar
Here are some numbers
Here is a Giac chipped a4 with k04 and injectors(b6)
http://www.ktrperformance.com/dyno_t....php?id_num=35
Here is a Stock a4 vs a chipped a4 (b6)
http://www.ktrperformance.com/dyno_t....php?id_num=36
cincyTT's Avatar
I'm make believe
ORIGINAL: crd945
I have know problem with what your running. I have a problem with the tuners selling you parts that you dont need are are far overkill with a stock turbo. And my Giac reference is for a ko4 turbo and it runs smaller injectors or even stock injectors and a higher fpr to supply the fuel
Old Aug 21, 2007 | 02:14 PM
crd945's Avatar
I already understand everything you are telling me. You just do not understand a few important things. b6 DO NOT UPGRADE FPR when getting 1+ software. NEVER! (never) (not even with giac) Dyno Dynamics dynos read low, and a k04 with software will NOT out down 220whp. Please see above for dyno charts. I really hope this is sinking in
Old Aug 21, 2007 | 02:18 PM
  #18
crd945's Avatar
a k04 with GIAC p16 software(aggressive) usually puts down around 190whp. That is the most aggressive k04 program I believe. (no where near 220whp on a dyno dynamics)
Anyway, I do not mean any disrespect, I am just getting annoyed at having to write the same thing over and over. I hope you do some more research.
Old Aug 21, 2007 | 02:21 PM
  #19
crd945's Avatar
TRUCE!
Old Aug 21, 2007 | 02:23 PM
  #20
cincyTT's Avatar
I'm make believe
READING > you
Me talking about increasing fuel pressure is with the b5's that run a ko4. They run the SAME injectors and fpr as the b6's but yetare to be able to handle the power of a ko4 with less injector. hhhmmm (hint hint)
The 225awhpi said was for a 225TT with a chip and full exhuast. Even then, they still have a little injector duty cycle left and you make no where near that power and use a 4bar and they use a 3bar.
