ATP GTRS kit or APR k04
Old Nov 29, 2007 | 07:26 PM
A4speed's Avatar
Default RE: ATP GTRS kit or APR k04
probably himself since it bolts up to the stock kkk manifold. it would be dumb if he paid someone to do it.
Old Nov 29, 2007 | 07:29 PM
14psi's Avatar
Member
there not much tuning to do wit it? cuz if i can do it myself, ur right, it would be dumb to pay some like $100/hour to do it
Old Nov 29, 2007 | 07:32 PM
A4speed's Avatar
you'd have to mail out your ecu or take your ecu to a dealer close to you and have it programmed. or you can install the kit, keep ur stock injectors in, keep the car in low boost and drive to the dealer to get it chipped, then you can put in the upgraded injectors.
Old Nov 29, 2007 | 07:37 PM
14psi's Avatar
Member
wouldu recommend getting aFMIC wit it too? or would i be alright w/o it?
Old Nov 29, 2007 | 07:41 PM
A4speed's Avatar
definitely!
for your bt setup to run smoothly you'll want:
fmic
3" turbo-back exhaust (2.5" minimum)
injectors (440 or 630cc, depending on what tune you get)
clutch (not needed right away, but you need something to handle the new power, i reccomend southbend)
Old Nov 29, 2007 | 07:44 PM
14psi's Avatar
Member
damn.. im gonna be broke... haha but thanks
Old Nov 29, 2007 | 07:45 PM
cincyTT's Avatar
I'm make believe
if you have any mech ability, you can swap a turbo. Its not as hard as you think, just takes time and organization (mark all vac lines and bolts)
Old Nov 29, 2007 | 07:48 PM
  #18
A4speed's Avatar
oh, silly of me, i forgot to mention sw/chip.
get unitronic for your software, it has the best tune for a B5.
Old Nov 29, 2007 | 08:53 PM
  #19
Beer Mod's Avatar
ORIGINAL: cincyTT
71r = 5k spool and 2k power band. Hp numbers are one thing, usable power is another.
71r = 20psi @ 4000 rpm and redline is 7200rpm. That gives you 3200 rpm of FULL BOOST not to mention the start to buildboost a tad after3000 rpms.
Old Nov 29, 2007 | 08:55 PM
  #20
cincyTT's Avatar
I'm make believe
Got a dyno, vag graph to prove that? The ones i have seen show otherwise
