ATP GTRS kit or APR k04
you'd have to mail out your ecu or take your ecu to a dealer close to you and have it programmed. or you can install the kit, keep ur stock injectors in, keep the car in low boost and drive to the dealer to get it chipped, then you can put in the upgraded injectors.
definitely!
for your bt setup to run smoothly you'll want:
fmic
3" turbo-back exhaust (2.5" minimum)
injectors (440 or 630cc, depending on what tune you get)
clutch (not needed right away, but you need something to handle the new power, i reccomend southbend)
fmic
ORIGINAL: cincyTT
71r = 5k spool and 2k power band. Hp numbers are one thing, usable power is another.
