Audi A4 Transmission Pan Seal
Old Nov 2, 2007 | 06:35 PM
mimgq2's Avatar
Default Audi A4 Transmission Pan Seal
Hello-
Can anyone tell me the specific details on replacing the A4 2001 A/T transmission oil pan gasket? 1. Does the oil pan require a gasket or just RTV?
2. If it requires a gasket does it require RTV? If it does require RTV will this lubricate the gasket and cause it to slide out and leak?
3. Do I install the gasket dry?
Thanks
Old Nov 2, 2007 | 07:29 PM
auditech79's Avatar
Default RE: Audi A4 Transmission Pan Seal
You would have to check to see what gasket is used on your car providing the VIN to the parts department at the dealer. Most likely its a paper gasket.
Always scrape off the old gasket, use some brake cleaner or electrical contact cleaner on the surface to get all the oil and debris off and put on the new gasket as dry as possible.
Bad886
Audi Q5
Apr 28, 2015 02:20 PM
ilackav8
Jul 21, 2011 03:52 PM
abydielsgli
Mar 10, 2011 02:16 AM
kartboy
Dec 30, 2008 10:18 AM
Mikies 100
Jun 21, 2008 09:32 PM
