Audi rents me a Jeep
you tried the rubicon with that truck. was it a four cylinder? did it have trouble spinning those tires? the liberty wasnt trail rated on the rubicon it was in moab on the casual route. the only jeep trail rated on the rubicon was the new jeep wrangler. i know it did it b/c i watched it on speed.
Jeep Trail Rated is supported by the Nevada Automotive Test Center (NATC), which has 45 years of off-road vehicle testing experience, including the creation of standards for the U.S. military.
The new Jeep "Trail Rated" badge indicates that Jeep 4x4s have been designed to perform in a variety of challenging off-road conditions identified by five key consumer-oriented performance categories, including Traction, Ground Clearance, Maneuverability, Articulation and Water Fording.
I drove my 1981 Cherokee Chief from Los Angeles to Dawson City Alaska. Didn't get stuck, cost me a ton in gas, but made it. Do that in any other stock SUV. Sure I could have done in the Liberty too.
From 4 Wheel and Off-Road:
"The Liberty is fully capable of tackling the Rubicon Trail, the mother of all unpaved roads, and has done that. We drove a Limited 4WD model over a gnarly trail used at the annual Camp Jeep event near Lovingston, Virginia. A Jeep engineer and I followed a modified Wrangler driven by an off-road club member. A Ford Escape or a Toyota RAV4 would not have made it, but the Liberty crossed steep ditches and gullies, where its short front and rear overhangs paid off. It wove through stands of tightly spaced trees, where its tight turning radius was a benefit. It clambered over big rocks and fallen trees and slowly forded boulder-strewn creeks with 18 inches of rushing water. (Jeep says it can handle 20 inches at 10 mph.) Its traction up steep, muddy banks was truly impressive, with no wheelspin. In addition to rear-wheel drive (2WD) models, two versions of four-wheel drive are available: Four-wheel-drive models come standard with Jeep's tried-and-true Command Trac part-time system. It works great. Shift from 2WD to 4WD on the fly with a slight pull on the hand lever. When the trail is looking really ugly, slow to 2-3 mpg and while still coasting, shift into neutral, and pull the lever up higher for low range. It works great. Our only complaint is that the Sport model's rear wheels bind up on dry pavement when accelerating out of a tight corner."
SidewaysTim
Sep 19, 2011 09:13 AM
