AUDI TURBO?
Old Sep 23, 2007 | 05:15 PM
omyfg's Avatar
Default AUDI TURBO?
Hey, i just bought a new 2000 a4 1.8 turbo quattro sedan.
I was wondering if i was to put a boost controller/gauge on this car would it help the turbo pull stronger and spool more? also what would be a good turbo to buy to put into this. And i would also like a blow off valve...
... which is a good blow off valve for the stock turbo?
Old Sep 23, 2007 | 05:19 PM
The Russian's Avatar
Default RE: AUDI TURBO?
for stock ou would want a diverter valve, similar concept, but instead of letting the air go into the atmosphere it puts it back into the system... but an upgrade k03/k04 is what people mostly suggest... i will do that on mine soon enough. and boost controler just lets you control how much boost you spool... duhh
Old Sep 23, 2007 | 05:23 PM
khj677turbo's Avatar
Use search everything you need to know is in there, im pretty sure you could even find out who actually shot kennedy.
Old Sep 23, 2007 | 06:23 PM
EVOLA4's Avatar
Search! This stuff is talked about all the time!
Old Sep 23, 2007 | 06:32 PM
cantdrive55's Avatar
Try the top few posts that are stickied. That will explain most of your basic questions.
Old Sep 23, 2007 | 07:03 PM
AteUrV8's Avatar
are you coming from the dsm community?? sounds like it. its a bigswitch from there turbos to audi turbos
Old Sep 23, 2007 | 07:04 PM
SAudi's Avatar
https://www.audiforums.com/m_535568/tm.htm
this shoudl suffixe since oyu have a 00+
Old Sep 23, 2007 | 07:17 PM
FASTER's Avatar
Tech Slut
oh god... another one of these posts... when you sign up for AF they should give you a pamphlet on chips, dv's, and HOW TO USE THE SEARCH FEATURE....
bkosonen
Apr 15, 2011 04:47 PM
03a418tnate
Aug 10, 2010 08:07 PM
delwyn
Dec 12, 2007 04:31 AM
mr V8
18
Jun 23, 2006 03:21 AM
benawadh
Nov 11, 2005 04:25 PM
