axle rub
Old Feb 24, 2006 | 10:27 PM
bajamoon's Avatar
Default axle rub
Hey everybody, I have 2003 a4 quattro with 2" neuspeed race springs with 18" wheels, after I put the springs on I noticed a rubbing in the drivers back , I checked it out and it looks like something is rubbing on the axle, I have read that vw cars get axle rub from the factory sway bar when you lower it any more than 1". I don't want to take to audi because they would charge me an arm and a leg to fix, would a set of H&R sway bars correct that problem, it only does it when I make a left turn, and I don't want to make right turns all day. thanks for any help.
Old Feb 25, 2006 | 07:05 PM
jja2.8's Avatar
Default RE: axle rub
what kind of shocks are you running with your Neuspeed springs?
Old Feb 25, 2006 | 10:11 PM
bajamoon's Avatar
they are stock shocks, need to save the $$$ for coilovers, I just ordered the h&r sway bar kit this morning, so what do you think it is, you would think if it rubs on one side it would rub on both.
Old Feb 26, 2006 | 01:12 AM
sandman's Avatar
i am way slammed and i have no problems. new shocks may be what you need.
Old Feb 26, 2006 | 01:16 AM
jja2.8's Avatar
maybe the shock in that corner is blown. coilovers would be great, but even a good set of shocks would be better than stock. i'd try the new shocks before the sway.
Old Feb 26, 2006 | 01:34 AM
bajamoon's Avatar
thanks guys, I will order some koni's tonight, how hard is it to install the rear shock.
Rolling Blackout
Dec 21, 2011 07:02 PM
ampower14
May 15, 2011 07:03 PM
SunnyShaida
Nov 16, 2008 07:59 PM
millenia
Aug 28, 2008 11:58 PM
sljone
Dec 8, 2006 08:08 PM
