b5 1.8t is running to rich
Old Jun 9, 2007 | 01:40 PM
discontained's Avatar
Default b5 1.8t is running to rich
P0175 is the code i keep getting, says my car is running to rich, i guess my o2 sensor is bad could i lean it out by addn more boost?
Old Jun 9, 2007 | 03:35 PM
CRAZYHAWK's Avatar
Default RE: b5 1.8t is running to rich
Being this code is for bank 2, and you only have bank 1, it seems bogus.
Reset it and see if it comes back.
Old Jun 10, 2007 | 04:49 AM
oops the code is P0171 - System Too Lean (Bank 1)actually. I reset it and it poped up the code again... within 20 min
Old Jun 10, 2007 | 10:58 AM
CRAZYHAWK's Avatar
Check for vacuum leaks.
"L" and "Y" formed hoses are known to crack.
Old Jun 10, 2007 | 01:27 PM
found 2 cracked vac lines, bout 5 feet of new hose, replaced almost every single line under the hood.. now it comes up with the rich code again, but on bank 1 now.. wth lol.
Old Jun 10, 2007 | 07:49 PM
CRAZYHAWK's Avatar
Reset it, and see if it comes back. Check to see if your spark plugs are black.
Old Jun 10, 2007 | 10:43 PM
Noobinator's Avatar
what do black spark plugs mean cuz mine are real black?
Old Jun 10, 2007 | 11:12 PM
lots of things, carbon build up, light detanation, fouled, too rich fuel mixture.. I checked the plugs, they still are in like new condition, a little fuel smell on them nothing serious tho. I belive its the gas im using ... when i use shell it never throws the code, but chevron seems to make it throw... (i use 93 only)
98a4T
Mar 25, 2007 07:38 PM
keko2004
Jan 12, 2007 04:53 PM
johnstef
Dec 24, 2006 11:29 AM
Trey25
Nov 20, 2006 06:37 PM
SuperS4
Jul 18, 2006 12:34 AM
