B6 02 Cooling fan comes on at cold start-up
Old Oct 15, 2007 | 08:44 AM
mudwalker's Avatar
Default B6 02 Cooling fan comes on at cold start-up
Just saved about $900 not having dealer replace my coolant flange and some small oil seep. Repair went well, just one problem. When I start the car cold, the engine (radiator)cooling fans come onuntil warm-uphas occured (about 4 min.).
Did I or can you installelectrical connection backwards???????????????????
Help!!!!!!!!
Old Oct 15, 2007 | 08:47 AM
mudwalker's Avatar
Default RE: B6 02 Cooling fan comes on at cold start-up
Oops, it's a 1.8T.
Thanks
Old Oct 15, 2007 | 09:17 AM
CRAZYHAWK's Avatar
Secondary air pump comes on during cold start. Check wiring
and look at the fan.
Old Oct 15, 2007 | 09:45 AM
mudwalker's Avatar
I checked the fans and they seem fine. Wiring to it was untouched by repair and functional at start of repair. I did gently "tap" the coolent temp sensor to seat it in the o-ringwhen re-installing coolent flange,and I am concerned I may havedamaged the sensor itself.
I first installed the sensor in the flange when on the bench, but later realized I installed it 90d out of wack. I pulled it, rotated it and it was hard going back in so I used a rubber pad andtapped it back in.
B5 Audi
Oct 20, 2010 06:28 PM
cbevan1
May 19, 2010 03:09 PM
ccomengee86
Feb 23, 2008 06:22 PM
rookie
Dec 6, 2005 04:45 AM
silver_rings
Apr 8, 2005 11:33 PM
